richard shelby
Here's an update on the water tanks. I finally got around to the starboard tank. You may recall from last week, the port tank was cut open and a Plastimo bladder was installed (see photo forum). The stbd tank has only one baffle, so I decided to cut inspection ports and coat the inside with epoxy. The short of it is that this is a MUCH EASIER option than cutting out the baffles. In retrospect, This would have also woked on the port tank, but with 2 baffles, that's 3 inspection ports which must be cut, in order to get to all the tank innards for coating. I used regular clear epoxy resin from the building supply, about a pint to coat the tank inside using a throw-away small paint roller and 1" brush. A pigmented epoxy might be better, so you can see where the stuff is being applied. I cut two square 8x10 holes and covered with 1/4" polyethylene boards (kitchen cutting boards) bedded in silicone, screwed down with stainless sheet metal screws. So far, so good...no leaks. The plastimo bladder is dripping somewhat from the fittings, but a few more ft-lbs of torque and some silicone should fix that. any questions: email me at shelbri@vetmed.auburn.edu......I'm ready to go sailing
