Water Tank cleaning access port - 1993 H33.5
gotons
May 11, 2022
15
Hunter 33.5 Gilbertsville, KY
Did this model come with an access location for cleaning the tank? If not, any advice before I put one in? The tank is funky and it needs a cleaning and can’t trust it until it’s given a scrub.
thanks!
Jan 7, 2011
5,828
Oday 322 East Chicago, IN
I don’t know if your boat would have come with one (most did not in my experience), but an inspection port can be added….
I installed a couple of 6” ports on my O’Day 322 30 gallon tank. The tank is baffled so, I put one on each side of the divider.
I used these Beckson ports.
Greg
gotons
May 11, 2022
15
Perfect, thank you! I’ve looked where I can see but don’t see anything. Don’t necessarily want to rip apart the V-berth.
gotons
May 11, 2022
15
I just wanted to follow up with this and let everyone that I took Greg's advice and did exactly that. If you have a water tank without an inspecting port, you should add one. It was disgusting in there.
