Got the the boat this afternoon. I was amazed that it only took me about an hour to flush the fresh water lines, head lines and the engine with antifreeze. It is amazing how much easier it is to do things the second time.
I looked at what it will take to remove the fresh water tank. There is a wooden lid for a shallow storage area over the tank. The bottom seems to sit right on top of the water tank. The bottom is attached to the sides of the shallow box with heavy woven roving. So the game plan will be to fire up the Dremel vibrating saw, cut the roving and then lift out the bottom to see what I am in for. I am guessing that I will have to cut the tank in half, at a minimum, to remove it. Hopefully just removing the bottom of the compartment provides sufficient access to cut it up.
I'd like to order the tank asap and be in a position to replace it quickly in the spring. Lots to do next spring, but I think I will try to get in the water early and then do the work at the dock in a temporary slip. The only thing that might hold me back is the following. I took my surveyors advice. I passed on painting the bottom last year. I just painted a four inch strip at the water line and called it a day. Boy it was nice to take a year off. The Pettit Hydrocoat I use is supposed to be multi-season anyway, but I have never tried it. Looking at it today, I saw quite a few patches that were down to the barrier coat. So perhaps I should strip the hull, consider another layer of barrier and then paint it.
