Water tank and inspection.....
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
The 423 has built in water tanks that don't have inspection ports. Has anybody cut them in? Would only make sense. How would you know what's in there and wouldn't you want to clean the funk out?? I clean my tanks twice per season and pull all sorts of funk out.
Greg
Gunni
Mar 16, 2010
5,937
I have similar tanks and take the approach - if it ain't broke, don't fix it. Unless there is something in there keeping the water from making it to the tap I treat it to make it safely potable and fill it from known water supplies.
The great thing about having two tanks is that you can batch treat each tank of water and prepare it for use. Using one tank at a time, and only taking on as much water as you will use in a week or two. Here is a very useful calculator to help you determine an accurate chlorine treatment regime using common unscented bleach to both shock, and maintain a residual chlorine content - effectively sanitizing the water.
https://public.health.oregon.gov/He...ater/Operations/Documents/ShockChloroCalc.xls
A shock will effectively oxidize the organics and dissipate, set a 1-2 ppm (mg/l) concentration to keep the water sanitized. A POU (point of use) carbon filter will remove the chlorine taste/smell.
With my 70 gal tanks the math works out to about a shot-glass each of 5% bleach to get them to 1 ppm chlorine.
JamesG161
Feb 14, 2014
8,088
Hunter 430 Waveland, MS
