Water system
Jan 29, 2011
16
Hunter 35.5 Baltimore
The water flow from my "fresh water" tank has recently reduced to just a trickle. The pump is running but almost nothing is coming out. Ideas?
DougMc
Hunter 36 Erieau Ontario
Check the nozzle on the fixtures. Mine have a screen in them that get clogged.
Jan 29, 2011
16
Thanks Doug and Steve. We did check the filter at the nozzle and even removed the nozzle from the faucet, which didn't change the flow rate. Up until this time, I hadn't even checked the system out. Any idea where I might find the strainer?
Jun 11, 2011
1,243
Hunter 41 Lewes
Sounds more like air getting in before the pump. Check the filter screen cup on the inlet side of the pump and all connections there. Just a thought.
