Water stains
Lee Y
Jun 5, 2004
43
- - Muskegon, Michigan
I have several water stains on the carpet above and on the sides of the window. I know how the water got in but am having a hard time removing the stains. I have used Dawn dishwashing liquid before with a soft tooth brush and towel but it doesn't seem to be working very well. One stain got worse. It is very frustrating. Any advise will be much appreciated.
Aug 11, 2011
1,015
O'day 30 313 Georgetown MD
I cleaned my entire carpeted walls with oxiclean using a carpet extractor (steam machine) I put two scoops of oxiclean into a pale of warm water, mixed it well, then poured that into the cleaning solution container. I went over the entire boat 4 times until the extracted water was cloudy, but clean. The more you do it the better the result.
Hunter 23 Tampa Bay
i used some oxy based spray I found at walmart, not the oxyclean brand. sprayed it one and used a shop vac to suck it and the stains out. did it a few times, worked good and was cheap.
Lee Y
Jun 5, 2004
43
Thanks
I used the OxiClean on the carpet today. Wow! that stuff is amazing. Thanks for your suggestions. The stains are completly gone.
