Harbor versus Blue Sea Water
Mr. Early (and all you other sailors, with this question):Running a water maker in the harbor, will surely increase the maintenance intervals on any unit and indeed will have an effect on the long term life of the unit's membrane element(s). As Mr. McKee stated in his posting, he saw about a 95% decrease in run time capability, when operating his unit in a harbor, versus operating at sea, in blue water conditions (60 hours at sea, versus 3 hours in a harbor), due to pre-filter fouling/clogging, thereby shutting the unit down, under a low pressure fault situation. Running any unit in a "brackish water" (harbor, bay within 3 miles of coastline) environment will surely increase the maintenance required and in the long run, will diminish the life of the membrane element(s) itself/themselves, overall. In other words, running a unit in a harbor, or in a bay is not going to destroy it, but it will certainly shorten the life of the filters and membranes and drive up maintenance costs. As for the "Little Wonder being the prime candidate", I can tell you that this unit, with its adjustable pressure regulator, is adaptable to various feed water conditions where many other models may not be, however, it is also still susceptible to the increased maintenance and shorter life span of the membrane, directly related to the feed water going through the unit. If one had to choose a unit, to be able to work well in various environments, even given the higher maintenance requirements, I suppose I'd agree with this choice, not only because the unit will work better than most in various feed water conditions, but also because the Little Wonder is probably one of the most user friendly and most field serviceable units on the market today. Not to mention the exclusive titanium fluid end manifold on the h/p pump, which is impervious to salt water corrosion and then some, earning it a lifetime gaurantee.
