Water pump?
C
Charles Krebs
Happy 4th to All, I have a problem with my saltwater system on my Catalina 30 with a "Jepson"? Water pump. I cleared my thru hull which was pretty much clogged, went thru the hose to the strainer/ball valve, then thru hose to pump. I took the face off the pump and the jacket and impeller all look good. It was suggested that I take loose the export side and turn on and check to see if water is coming thru? Are there other thoughts on this situation, the fact is I'm not getting water "spitting" out the stern. Thanks and Best regards and keep up this terrific, owner support site. Charlie
Step-by-step
Charles, we had the same problem recently. Try this, which means you need to track back to every single component of the system. The notes below are how we blew out the crud in the intake. You seem to have done that already. You need to check why and where the water isn't getting to the muffler and out. Have you checked your exhaust riser? How's the HX? Pump faceplates often get scored and will not allow the pump to pull prime. Check the pump rotation with the cover off, the kill switch UP and turn over the engine. Lotsa different things to check. The engine is an M25 with an Oberdorfer pump. **************** **************** Among the interesting little “tidbits” of information that I’d remembered reading about on the website had to do with cleaning out the raw water intake with a dinghy foot pump. On a nice mid-winter March sail with Ken Heyman, our treasurer who was here visiting, we had just left the South Beach Marina and were motoring over to see the “Lady Washington,” one of the tallships that regularly visits the Bay Area and has cannonball encounters of the close kind with fellow tallships. Since it was cold out, there seemed to be a bit more white smoke from the exhaust than usual, which I attributed to the lower air temperature. Upon checking the temperature gauge, we noted it was pegged and stopped the engine immediately. Ken and I went through a checklist of actions we could take. Sailing back to the marina was not among them, since there was no wind and the end of the ebb was setting us north towards the Bay Bridge. Thru hull strainer clear – check. Raw water entering – check, but a trickle and less than expected. Raw water pump impeller in one piece – check. Raw water pump turning – check. Spare raw water pump gasket to replace cover – check. Temperature gauge working properly – check. Hoses and thru hull clear – hmm… We got the dinghy foot pump out from the lazarette, replaced the strainer and opened the seacock. Because the arrangement of the hoses and the strainer on “Aquavite” aren’t configured to connect the pump there, we removed the hose from the raw water pump and used the dinghy pump at that end of the hose. That turned out to be actually be easier than trying to work under the head sink. There was significant resistance at first, but after setting the three way valve on the foot pump to a higher pressure setting, the pump started working. Whatever had been clogging either the thru hull or the line was flushed out. Once everything was reassembled, we started the engine and all was well. Lesson Learned: It pays to read the material on the website because you just never know when you’ll be faced with an insurmountable problem only to find out that one of our skippers had “been there – done that” and had most importantly reported it for all of us to know. Thanks to Ken for his analytical assistance!
