Water pump
Jul 6, 2010
28
Catalina 30 Bainbridge Island, WA
My water pump has white powder on the edges. What's going on?
Thanks,
Tom
C-30
Assuming raw water pump (you didn't say): Usually means nothing. As long as the faceplate is tight, it's just seawater wicking through the gasket. Clean it up and keep an eye on it and your tempt gauge.
M25 engine????
Jul 6, 2010
28
Thank you Stu. Nice to know whats going on. It's a raw water pump as you mentioned.
Tom
Mar 6, 2008
1,417
Remove the cover. Clean the surfaces. Apply ample lanocoat to cleaned surfaces and reinstall the cover. The dried up seasalt indicates water is leaking out. This means air might be sucked in and pump will not prime causing no water circulation and high engine temperature.
