water pump
alans
Oct 15, 2006
23
Hunter 310 patchogue
hi, i have a yanmar 2gm20f, noticed my water pump dripping. would you recommend a rebuilding kit or to replace. its 10 years old. if replacing who would have best prices? thanls alan
Jun 2, 2004
5,802
Used a rebuild kit once. It still leaked. To find a price I would have to start Googling.
G
Guest
Pump
Hi Alan, which water pump? Our 1989 2GM used a pump to bring raw water into and through the heat exchanger to cool the encapsulated system. A separate pump is used to circulate coolant within the encapsulated system. I used a kit to rebuild the former raw water pump that was leaking, which included a synthetic impeller, seals and seal lubricant at a much lower cost than a new pump. This kit was available from our local Yanmar service depot. Our pump did not leak after I did the repair.
Terry Cox
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
Call Depco Pump http://www.depcopump.com/contact.htm
They are easy to work with and fix all pumps. I used them a few years ago. Then I messed up the installation by tightening the drive belt too much. They backed me up and did a rebuild for no cost. Amazing.
Oct 29, 2005
2,363
search for posting by Maine Sail. he has instruction on how to rebuilt your water pump. I did mine for my 2gm20f. bought all parts (bearings and oil seal, o-ring...) from bearing supply company. very very much cheaper than yanmar dealer. you'll need some basic tool light bench-vice, socket spanners hammer, pieces of wood etc... easy. mine no longer leak after rebuilt.
