Looking for a boat yard to replace the seawater pump in palm beach or Ft Lauderdale fl.
It looks as thought the engine may have to be lifted off the motor mounts or pulled, the motor mount is in the way of getting the pump out and the bolts are highly rusted on both the motor mount along with the pump. A lot of neglect by previous owner.
The other alternative would be to replace the inner seals on the pump while it is attached to the motor.
Any recommendation on a yard in the area that can perform the task would be appreciated.
Galley has been fully remove for easy access.
