L
Leon
I have a 1982 Catalina 27 with a 2004 rebuilt Atomic-4 inboard gas engine.I had the problem with my water pump few weeks ago. The water was not coming out.So I removed water pump impeller, found out that most rubber blades were broken. I slided impeller shaft out of pump housing and had the the broken impeller replaced. I reinstalled the cover plate with a new gasket. I restarted the engine and everything seems ok as I could see the cooling sea water coming out, but with white smoke (steam? or burned oil?). The engine temp seems ok as it was kept at 170C when the engine was idled.However, the engine temp was rapidly increased to above 200C when I tried to motor out the boat even within a very short time, but water was still coming out indicating the cooling water was running well (?).I checked the engine and saw a serious leaking at water pump as shown in the attached pic, but found no leaking around the cover plate. I was not able to "see" where is the leaking. I could "feel" the water dripping from the body of the water pump. Is there anyone who has knowledge about any possible location of the leaking? I once suspected the rusted grease cup? and how is the connection between the engine temp and the water leaking? And, what it could tell me with the white smoke coming out from the cooling water? Or, did I miss something when I reinstalled the water impeller?
