Water proofing zippers….
NYSail
Jan 6, 2006
3,147
Beneteau 423 Mt. Sinai, NY
So new bimini zippers leak. What product do people use to waterproof them.
thanks
Greg
arf145
Nov 4, 2010
496
Beneteau 331 Deale, MD
My bimini zippers have flaps, but they leak a bit and I kinda expect that. When you think of the sheer number of mating surfaces in a zipper, it's hard to picture them being waterproof.
Likes: ggrizzard
capta
Jun 4, 2009
4,952
Ours too had flaps covering the zippers on the outside.
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
thanks
Greg
You can't waterproof zippers that aren't waterproof zippers. And that's it! You can lube them, but it won't keep water out.
The bimini should have flaps to cover the zips.
I've never seen waterproof zippers, i.e., dry suit zippers, on a bimini or dodger, etc.
RussC
Sep 11, 2015
1,642
Merit 22- Oregon lakes
pretty unlikely to waterproof zippers but if it's a "plastic" zipper (or metal for that matter) you can sure improve the ease of action and prolong it's life by spraying it with McLube Sailkote.
jviss
Feb 5, 2004
7,089
pretty unlikely to waterproof zippers but if it's a "plastic" zipper you can sure improve the ease of action and prolong it's life by spraying it with Sailcoat.
Better to use a zipper-specific lube, like Zipper Ease.
jviss
Feb 5, 2004
7,089
yup. I put Chevy oil in my Ford once and it blew up also.
Not a good analogy. Oil is oil. Sailcote is not the same as conventional zipper lube. Sailcote is a dry lube. Zipper lube is more like a hard grease, similar in texture to a Chapstick. In fact, Chapstick would probably work!
Jan 7, 2011
5,714
Oday 322 East Chicago, IN
I have used chapstick on my Mack pack zipper when it gets a little sticky!
Greg
Likes: Rick D
jviss
Feb 5, 2004
7,089
Greg
Yes! Something like Sailcote will wash off pretty quickly. The waxy zipper lubes, like waterproof zipper lubes, as used on soft cooler and drysuits, and products like Zipper-ease and Snap-Stick will stay put in a downpour or even underwater.
