Water pressure
121
Hunter h41 San Francisco
I am getting very low water pressure on board from my dock side water inlet. Any thoughts on where to start looking?
Oct 30, 2011
542
klidescope 30t norfolk
try the screens on faucets and valves next you may have a screen on inlet fill for your water supply or the po might have put a filter on board
Jun 14, 2007
185
Hunter 45cc Florida
First check to see that you are getting good pressure at end of hose before it goes into the boat.
There is a check valve attached to the water entry fitting inside of the boat that may be cloged and not opening all the way
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
My dock side water connection in anchor locker. 35psi regulator . Standard water filter connected in locker before hose from dock. Always filtered water into tank. After a year or more filter can get full. My water pressure did same for a while. Then marina had to do some main water line repairs. After repairs I noticed a big improvement in water pressure . That was my issue not the filter that I was thinking was time to replace.
