A few possibilities
Air in the plumbing that hasn't all been bled out yet...if the water level in the tank is low, rocking/heeling and sloshing can drop the level below the top of the tank discharge, which can cause the pump to cycle when it loses prime. Or, unless you used hose clamps, there could be an air leak on the inlet side of the pump... Or, a defective diaphragm in the pump.Unlike Ed, I find it better to turn the pump on when I come aboard and leave it on till I leave. It doesn't draw any power except when water is running, and making it prime every time a faucet is turned on is just adds extra wear and tear on the pump. An accumulator reduces the wear, but it's still a PITA to have to leave the sink or the head to turn on the breaker with soapy hands, which will always be the case.
