With the shower drain connected directly to the sump pump I can see no way for water to come up from the bilge. But, there is a window above which could be suspect or, maybe, a deck leak (possibly at a stanchion.
Had shower window replaced under warranty since it would not seal. This is only hatch of this type on the 380 and will not stop leaking by tightening, this only cracks the hatch or its frame. If hatch frame not cracked, new gasket may solve problem.
