Water lock (muffler) in/out connections H31
rafip
Oct 27, 2010
7
Hunter 31 Hertzliya
Hi. Can anyone check his H31 boat (mine is H31 1985) and tell me which one is the input or output connections for the built-in water lock (muffler)? I took the hoses apart and I am not sure now. Is the short hose going to the throughull, connects to the front or rear connection of the water lock? Thanks.
25
Hunter 31 Sea Isle City
The one closest to hot water heater is in the one close to fuel tank is out
rafip
Oct 27, 2010
7
Hunter 31 Hertzliya
Water Lock
Mine cracked and added a vermalift to top of old
Thanks. While I am at it, is there a way to test the unit? I know it supposed to allow water/exhaust flow in one direction only.
If it leaks -- salt water will be presnent in the bilge. Right?
I did not see any way to get to the unit as it is part of the hull.
Jan 5, 2013
25
Yes and will have soot/oil in it. No way to fix if it leaks. I just attached a new one on top.
