Apparently no one takes winterizing too seriously in the Pacific Northwest however my 373 seems to have sprung a water leak in the cockpit shower mixer during a recent cold snap. Just wondering if anyone has had ever repaired this specialized tap - I can turn it off just enough to stop the freshwater pump from cycling but it leaks when using the hose and likely won't hold pressure in the lines for much longer. It would be nice if simply tightening the joint on the mixer or a washer replacement would suffice?? Does the handle on the mixer move in and out ? - seems there is a gap between the base of the mixer and the handle that twists for hot and cold and moves up and down for on/off?
Of course I expect I will have to replace it but perhaps an easier fix?
