Any ideas????I have water leaking into the cabin of my 260 from a spot on the port side of the boat, exactly perpendicular to the mast. The water appears to be seeping in from underneath the liner in the cabin roof. It leaks out right at the spot where the inside liner meets the fun-fur, runs down the fun-fur & in behind the cushions on the settees... Anybody seen this before? What was the source of the leak? Were you able to stem the flow? The amount of water after a good rain is enough to wet the cushions pretty good. Your comments or ideas are appreciated.Thanks!
