Yes! Water leaks everywhere there.
In my 1981 Cat 30, water comes in through all the old screw holes in the cabin above the nav station. When I did a temporary repair on a leaky window, I discovered the fibreglass has delaminated at the bottom of the window under the frame. The real repair that I plan on doing is to remove the windows, dry out the fibreglass, and inject epoxy to seal it up, and then reseal and reinstall the windows.I found out yesterday that about 2 feet aft of the nav station light holds a lot of water. I removed a screw holding up an old stereo and water streamed out.I was toying with the idea of putting a small drain there leading to the bilge. I'm not sure how far back the low point is. I do know that on my boat, if water is coming out that light, there's a lot more water sitting further aft. Ideally I could seal up all the leaky windows and there wouldn't be a problem, but that's probably not going to happen. Nothing ever ends up perfect on my boat!I would be interested if anyone else has put a small drain there. Consider also that the electrical panel is probably getting wet too.Good luck!
