water leak
Oct 27, 2012
8
Catalina 270 Paynesville
My 1996 Catalina 270 has developed a water leak. It is definitely salt water. yet to find source but suspect either keel or depth sounder thru-hull as ingress is along port side of cabin flooring. Any suggestions/hints ?
John Reeves One Day Catalina 270
How did you find out where?
Could it simply be your stuffing box? Do you have an inboard engine?
Oct 27, 2012
8
Definitely coming from forward of the bilge cover as have checked the area under the diesel motor which has been thoroughly checked and serviced 2 weeks ago. Am wondering whether it might be from the thru hull depth sounder fitting
