V
Victor Robert
During a recent rain, I noticed water dripping from the cover plate at the top of the compression post. When I removed the cover plate, water poured (not dripped) into the salon. This explains the drips appearing from the headliner elsewhere, as far away as the forward cabin. I have re-siliconed the PVC pipe that holds the wires. Unfortunately, the glue did not adhere well to the gap between the PVC and the surrounding painted metal, so I will have to let it dry and try again.My question is: Where is all this water coming from and where should it be going instead of into the salon ? Is there a drain hole on deck that I should clear, or is this normal ? Your shared experience will be appreciated.Victor Robert"Bluebird"
