L
Lou Neidich
A water leak was found at the start of the 2001 sailing season. I found water laying under the front V-Berth. Investigation revealed the water was comming from the Window above the V-Berth and from under the port side toe-rail. This was expense to repair, the complete settea had to be replaced, a lot of custom work. I was very unhappy with the result of my inquiry with the Hunter Manufacture. If anyone has had a problem like this I would like to hear your comments.
