I have searched this site many times to see if anyone has successfully stopped the water intrusion on an 1986 H23. I have covered my companionway, no water intrusion there. I believe it may come from the lazarette. But how does it end up in the three bilge areas? I have syphoned out 5 gallons every time it rains. This cannot be normal for H23's, or is it? The windows do not leak, the water never enters the top and runs down the walls. It does not show up in any of the seat compartments. Just fills the area under the lazarette with about 2.5 gallons and fills the bilge compartments with 2.5 gallons. Any suggestions? I have been in the boat in rain and cannot see any area taking on water. Of course I don't get into the lazarette and stay for a rain fall.
Also the elevated battery area is always wet. Would it jeopardize the integrity of the boat if I cut out the wood plate and replaced it with a fiberglass plate? And could this area be connected to the water intrusion from someplace?
I also am removing all the carpet on the walls and top. I have seen several suggestions regarding the burning off of the fiberglass. I would like to add, take a heat gun and it will remove the carpet& singe the fiberglass, making for one clean sweep to paint.
