Jim Petersen
I have just purchased a 1993 MacGregor 26 Water-ballasted boat and had some problem with water getting into the hull when sailing the boat agressively. It seems to be splashing up thru the tube that the centerboard cable runs thru. Putting a cork into the tube with a small hole to accomadate the cable seems to have solved the problem but I wonder if there is an underlying structural problem, or does the water often splash up thru this tube? Thanks for you advice.
