I bought a 1977 27 ft hunter last winter that had been sitting for 3 years. During that time the cabin flooded and the engine and trans were partially submerged. I got the engine started but the trans would not go into neutral, when I opened the trans filler plug the water just came pouring out. I pumped out the oil-water mix but there is no way to get to a drain plug. Is there a way to flush out the trans with something that would clean out the little water-oil mix that must still be in there. I'm hoping if I can clean it out and refill with new fluid the shifting into neutal will be solved. Any help would be appreciated
