Water in the Swim Platform Locker
Bruce Leidal
I get water in the lock under the swim platform. Any thoughts of where it could be coming from??
L
Larry Grasse
Mine TOOOO
there is a long list of fixes in the old article files. I resealed the Swim ladder and that worked for awhile I did notice when I have a folling sea in our case I have to be in reverse just after a large boat comes by then My rear compartment get water in it I am going to seal the hatch with weatherstriping and look for a nother folling sea.
Bob Peters
waves splashing on stern
My boat is usually on a mooring but near the end of last season the marina put me in a slip for about 2 weeks prior to being hauled for the Winter. A wind storm stirred up the water and waves were splashing up over lower half of stern. Water worked its way under the covers and into that compartment (this is on a 336). I would assume a choppy following sea would give same results.
Bryce Custer
Swim Ladder
Had the same problem. Removed and resealed swim ladder and leak has gone away. (Not only leaked on the water, but during storage as well)
L
L. Vander Hoeven
Check the Hinges too!
I also had this leak on my 29.5. I removed and remounted the swim ladder. I also noticed that water would also get in around the hinges of the locker doors. My 29.5 was a constant challenge to find and repair leaks!!. Good Luck
robert
rear locker leak
yup, it took 2 years , two trips to the yard, the last one hunter picked up the tab for resealing the stern hull deck joint(2thousand bucks) when all along it was the ladder bolts that were not sealed well and caused the leak.
