G
Guest
I have a 1984 Catalina 30 with a 25 HP diesel engine. I had some trouble starting the engine; it cranked once for a second and shut down. This happened repeatedly. I put a fully charged battery in -- same result. When I had a mechanic check it, he said there was water in the engine and the muffler was full of water. Although I never crank it for more than 10 seconds, I was told that the cumulative effect of repeated crankings - even for a second at a time, allows water to fill the muffler and enter the engine. Another mechanic told me that Catalinas have a very flat system with the muffler being just slightly below the engine, barely meeting the standard.If anyone has had an experience like this, perhaps you can advise me about what can I do to prohibit this from happening again? Thanks.
