Ray Trombino
I recently found some water in the bilge in front of the the water tank. It appeared to be seeping through the bulkhead forward of the tank. To test a theory, I drilled a small (1/4 inch) hole through the bulkhead, about midway up. I got about 6 gallons of water pouring through the hole. I then drilled two more holes at the bottom, and took out another 6 gallons of water. So now, I am installing a bilge pump in the forward bilge. I believe the water came in via the small hole used for the bolt to secure the anchor locker, but I'm not sure. My questions: Are there any other "sealed" places for water to hide? How does one access the area in front of this bulkhead without disassembling the boat? Has anyone else had this problem? (Check your trim - my boat was down at the bow by about 2-3 inches).
