This is mostly a story rather than a specific request for advice but any thoughts are appreciated.
Last weekend I took my lady and another couple on what was to be a 3-day sail on our 1986 Hunter 34. On the 2nd day we started sailing in brisk wind and the boat was heeled over. One of my guests went below for something and quickly returned saying there was water sloshing around in the main cabin. Alarmed, I went below to investigate. Sure enough there was a puddle of dirty water in the cabin and the bilge was almost full. To my further alarm the bilge pump didn't seem to be working. I toggled the manual breaker for the pump and I was relieved to see the water quickly drain away. An inspection of the sea cocks and other critical places revealed no obvious leaks but I was taking no chances - we immediately motored home. In the few hours it took to get home the bilge filled up again (albeit more slowly each time) and I needed to manually activate the pump a few more times.
With the boat secured, my co-owner and I did a more thorough inspection and the only thing we could determine was that the float switch for the bilge pump was not working. We found a slow drip from the propellor shaft near the stuffing box but it eventually stopped once we were tied up. Water continued to accumulate in the bilge but now much more slowly. We could see that the water was coming from other parts of the bilge and it was taking a while for the last of it to drain into the primary compartment where the pump is located. At this point the accumulation seems to have stopped altogether.
While we initially feared the worst, it now seems possible that the water had accumulated over a much longer period of time than I had first thought. We may have had a slow leak for a long time but didn't know it because the automatic bilge pump continued to do it's job and clear the water. (We regularly check the bilge and it's always been almost dry.) The sudden failure of the float switch allowed the water to accumulate and fill the bilge.
While this comes as a big relief we are still going to have our marine mechanic do a thorough inspection of the boat and advise us on whether we should pull her out of the water. We will obviously replace the float switch shortly.
I have heard that all boats leak a little bit from places like the keel bolts or the stuffing box but I'm really not sure how much is acceptable. Is it normal for the bilge pump to need to regularly engage and clear out accumulated water? I'm also curious as to why our leak seems to have nearly stopped now that we are at the dock. I'm left rather unnerved about the whole thing...
