Steve
I have an '87 Daysailor 3. I have an ongoing problem with the bildge compartment filling up with water every time I go sailing. It doesn't seem to cause any interference other than the extra weight. I usually pump the water out (with a hand pump) but it fills up again and again. The hull is completely sealed with the exception of the opening for the centerboard. The water must be coming in from that point but I can't figure out why. So here are three questions. Does anyone else have that problem with their DS3? If so, were you able to fix it? Can you pass on any advice to me?Thanks!
