Water in oil?
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi all.
I siphoned anti-freeze into engine recently - using a bucket to
gravity-feed it down to the inlet then starting engine.
I noticed a "blob" of oil emerge from the exhaust outlet (and go into
the water to my shame).
Do this mean that the seal keeping water out of the engine has failed?
(Due to excessive "head" of inlet water, 1 meter??)
I'll check the engine oil for signs of emulsification next time I'm out.
If I have to replace the seal, which seal is it & how difficult to replace?
(I have a set of MD6 seals).
Thanks
John V1447 Breakaway
John A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
Feb 13, 2010
528
John, I never siphon antifreeze Into my engine. I take the hose off
the through hull and drop the intake hose into the antifreeze. I run
the engine and let it pump the antifreeze through. This lets the
exhaust gases blow the excess antifreeze out the stern. IF you pour
antifreeze in it can get high enough in the exhaust to enter the
engine through an open exhaust valve. There is no seal to keep
water out of the engine except at the water pump and that is only to
keep water leaking from the pump entering wile the engine is
running.
Doug
On 03/02/2015 06:58 AM, John.Kinsella
John.Kinsella@... [AlbinVega] wrote:
Oct 19, 2019
921
Thanks Doug.
So am I likely to have a problem?
Suggestions welcome!John V1447 Breakaway
On 02/03/15 16:54, Douglas Pollard
dougpol2@... [AlbinVega] wrote:
mnhdl
Oct 31, 2019
83
Hi John,It happened to me once, I've done 3 oil change in a row and that's it...Engine runs perfectly fine since.MarieTo: AlbinVega@yahoogroups.comFrom: AlbinVega@yahoogroups.comDate: Mon, 2 Mar 2015 11:58:01 +0000Subject: [AlbinVega] Water in oil?
Hi all.
Thanks
Oct 19, 2019
921
#ygrps-yiv-72262977 pre.ygrps-yiv-72262977blue {white-space:pre-wrap;word-wrap:break-word;font-family:sans-serif;margin-top:0px;}#ygrps-yiv-72262977 div, #ygrps-yiv-72262977 p {}#ygrps-yiv-72262977 a {color:#226EF9;}#ygrps-yiv-72262977 blockquote {padding-left:9px;border-left:1px solid #CFCFCF;margin:0 0 0 .9ex;}#ygrps-yiv-72262977 pre {white-space:pre-wrap;}
Merci Marie!
John___
On 5 Mar 2015, at 20:25, "marie marie
mnhdl@... [AlbinVega]" AlbinVega@yahoogroups.com wrote:
