Water in oday 22 foot
jim edlund
I have a hold in my cuddy is is suppose to be their you look in it and it has a lot of water in it almost to the top is this just ballast or do i have a leak and should i get the water out also for winter storage do i get water out ! thank you!
W
Warren
Water In The Basement!
The water should be pumped out of your bilge...In the winter if it freezes and expands there could be damage. Buy one of those cheap hand pumps at a marine supply store. Obviously, I can't tell if you have a leak. Check any through hull fittings and the lower rudder hinge. There is a good chance that the water is coming in through leaks at the toe rail or windows..you can reseal these with Lifecaulk. Good Luck!
