Water in interior light
Mar 5, 2014
45
Oday 23-2 Oriental
I went down to my 23-2 Saturday after a week of rain (maybe 4" total), and discovered that my interior light over the port settee was full of water. As in, there was 3/8" of water standing in the light fixture lens. Obviously I have a deck/cabin leak. My first thought was the chain plate, which is about 8" away & has an old water repair, but everything looks dry there. No sign of water coming in around the port light on that side of the cabin either. Any ideas where else it could be coming in that would collect in this location?
Aug 3, 2012
2,542
Genoa track? Rub rail? Did you take the light off and look at the screw holes? Is there a fiberglass liner with a gap between the liner and the cabin top?
Mar 5, 2014
45
Oday 23-2 Oriental
There is the liner with a gap. The rub rail & genoa track would have to run up hill.
Mar 2, 2008
406
Cal 25 mk II T-Bird Marina, West Vancouver
I had a similar problem with one of my cabin lights. I rebeded everything in the area with butyl tape and it didn't help. Only took about three years to find that one of the light fixture mounting screws was longer than the others. Long enough to just penetrate the deck. Looked like a black dot on the outside but in heavy rain it let a drop every couple of minutes to enter the light. Don't need to use a winter tarp anymore.
Likes: wing15601
Oct 2, 2008
3,811
Pearson/ 530 Strafford, NH
On our previous boat I chased some drips and rebedded genoa track, chain plates, stancions, etc. I never found it even after having a deck repair done in that section. With 4" of rain water can travel quite a ways. Keep at it.
All U Get
Gene S
Nov 29, 2015
181
Delphia 37 Tacoma
I have a Laguna 24 that the V berth light rusted out but couldn't find a leak. What I think happened is during cold weaher, condensation ran down the painted overhead and collected there. A heater used during the winter cured it.
Likes: agprice22
Oct 2, 2008
3,811
The V berth in our prior Catalina always had a little water get in from the anchor locker. I had to remind myself not to dip the bow in oncoming waves when we were out. I found the wire chase along the toe rail inside the anchor locker was where it would sneak in. I plugged the wires with some plumbers putty and went back to romping down the waves.
All U Get
Aug 3, 2012
2,542
I have a small bilge area, really 3 small bilge areas, on my 272 that get 2-4 inches of water in them when we launch... It always makes me nervous.
It is all condensation. Once I dry it, the bilge is dry all season.
I would buy the condensation theory.
Mar 5, 2014
45
Oday 23-2 Oriental
Thanks for the suggestions. I really don't think it is condensation. Tropical depression 2/Bonnie should bring some rain this weekend, hopefully I can figure it out then.
Jun 28, 2009
104
1984 O'Day 28 Bath, NC
Had a leak that filled the interior light too. Traced it down to a leaking seal on the lexan port light.
Jun 28, 2009
104
Yes, on the 28. The seal between the port and cabin was bad and allowed rain water to leak behind the port and run between the the cabin and liner. The water found its way to the cabin light. The lens would fill up when it rained and drip on the settee. I was glad to finally fix that. Find a helper to stand in the cabin and look at the port for leaks while someone runs a water hose around the port. That is how I found my leak.
