G
Glenn Ellis
Now that I cleaned the heat exchanger and reinstalled it, I began the process of purging the air in the fresh water circuit on my M25 engine. Engine under load at about 1500 rmp, temperature spiked fairly quickly, shut down and added more coolant, restarted, opening areas to bleed air and finally it would remain cool, thermostat appeared to be working properly and good water flow out the exhaust. However, when I went below to check all again there was oil being spit out the crankcase vent line on the port side of the engine. The oil level was exceedingly high and was turning slightly gray ... water. There was no indication that the engine was having a problem. I quickly shut down and drained all oil out of the crankcase.I have not had any water in the crankcase before so my thought is that air in the system may have blown a weak head gasket. Besides the head gasket, cracked head, cylinder liner or block, where else may fresh water get into the crankcase? I read Nigel Calder's procedure for flushing the engine with 2 parts Butly Cellosolve to 1 part SAE 10 oil. He did not mention correcting the leak first, but I would think it obvious prior to flushing the engine first. Am I correct?I'm going to the archives now.
