Back to Tom
Thanks for the information on hatch reseating. The wire idea sounds perfect! On the rail bolts, I have had leaks in the same locations. I have tightened the rail bolts, the mounting bolts for the connection on standing rigging, and mounting bolts for the lifeline stantions that are visible. Three diffent sizes of bolts, as I recall: 1/2" socket for the rail bolts, 9/16" for the stay connections and maybe 7/16" for the stantions. Extended sockets, a drive extension, and a universal joint adaptor on the socket make this job MUCH EASIER. I have never re-sealed the rail or bolts, just tightened the bolts. I did this once about a decade ago and again this season. The sealant under the rail is still plyable after more than 20 years. I do not know if there is a recommended tension on these bolts, or a procedure for re-sealing them. I'd be interested to know if there is one. On the mast shimmy, I don't recall ever having the same problem. I have felt some vibration in some winds - but it was felt more than heard. Is the noise caused by halyards or electrical wires in the mast? If the electrical lines are the suspect, the zip tie idea sounds good to me. I lead the main halyard to a loop on the lifeline stantions and and put some tension on the line. This solves any noise from halyard in port. If the shimmy is pronounced, maybe the tension on your standing rigging needs to be checked. I used the loos tensioning guage to check and ajust all stays about a decade ago. It may sound like I spend a lot of time working on the boat, but I have had her for 14 years, so these projects are spread over a long time. I think these are great boats, stable, fast for a cruiser, and fun. I hope you are having as much fun with yours.Thanks again for the info on the hatch.
