E
Elcamber
I own a 1995 MacGregor Classic and have experienced an increasing amount of water leaking into the bilge. I have had this problem to a lesser degree since purchasing the boat new in 1995 however the volume has increased on the past year. The amount of water in the bilge is directly proportional to the level of water in the ballast tank, indicating a leak between the tank and the hull. If I only let the level in the ballast tank come up to about 8"- 10" below the observation plug the problem is reduced however this is about 4"-5" less than the recommended level which represents a considerable volume. I have brought this to the attention of the dealer I purchased the boat from but so far no solution. Has anyone else experienced this problem and do you have any ideas on how to deal with it.
