Hi,I have a 1981 Hunter 27 and have discovered that my bilge pump sits in some kind of a pan or liner and there is actually several inches of water underneath it that is only accessible through a small hole. I am comtemplating cutting a hole in the pan to drop the pump down onto the top of the keel (keelbolts) itself, but I wondered what other folks might have done to deal with this water. I end up with several inches of water in the starboard locker, which is dry at the mooring, but wet after a sail. I presume it comes from under there somehow.Thanks,Dan
