Hi, All,
I have a small amount of water which comes into the bilge on my 2000 Beneteau 311. The water is in the bilge section adjacent to the galley which contains the galley sink through-hull, but the water isn't coming from that--it's coming through the weep tube which leads forward. None of the other bilge sections show any water at all, and I've even run an experiment in which I shut off the reefer and removed the fresh water tank, but the water is still there. The same amount of water always slowly trickles in: maybe 1/8". The water is salty. I see no evidence of water anywhere else, including the keelbolts. The water is definitely not coming from around the knot/depth transducers.
Do you guys have any suggestions as to where to look? It's a bit of a mystery to me.
Thanks,
Dan
Thanks,
Dan
