So - here goes -
My 1985 Ticon 30 with a Kuang hot water heater connected to a Volvo Penta 2002 diesel has decided to start leaking from inside the tank (not at the fittings).
So - time to replace it.
Question - what to look out for in this job ?
There are only 4 hoses (cold In, hot, OUT, and 2 lines running to the engine for the heat exchanger.
That should be easy - however - it's a boat, and nothing ever seems to be easy.
My big question is around the 2 hoses from the Volvo 2002 Penta engine - what "special" stuff do I need to do when installing the new heater ?
Common sense would indicate that I disconnect them, plug to stop leakage, and reconnect to the new heater.
HOWEVER - I *think* these hoses contain prestone (?) coolant - so - when I change the tank, what other stuff is required on the engine ? (for example - do I need to do anything to the engine heat exchanger ? vacuum pump the cooling system ? add coolant ? re-pressurize the engine cooling system ? etc. etc...?) You get the drift - basically - other than removing the hoses from the old tank and clamping them to the new tank, what wierd and wonderful things do I need to do to make sure both my engine and the new tank work in harmony ??
Advice please !!
Thanks,
Paul
Advice please !!
Thanks,
Paul
