on my '01 320 I've noticed that my water heater pressure relief valve leaks when the heater reaches full temperature. It doesn't leak when heated by the engine or when water pressure is on but the heater turned off. It is a seaward 6 gallon. Does the heater have an adjustable thermostat? It seems like replacing the PRV, heating coil and or thermostat is not that expensive but only want to replace what is necessary.
thanks for the help
Steve
thanks for the help
Steve
