Mick
I'm trying to get the water system on my 1987 Hunter 28.5 going. I have managed to find the water tank (which bright spark put it under the anchor?). The pressure water works for the cold, although the pump noise is high. I do not seem to be having much luck with the hot water. There is no pressure or heat. I've looked for another switch but there is none on the control panel. I also could not see any switch on the actual heater? Any help will be appreciated! - Mick
