I have a 2005 Hunter 45 CC, with a 11 gallon Force10 Water Heater, (now known as Kuma Water Heaters). The original Pressure Relief Valve was leaking (10 years old) so I replaced it with a new one. Now there is a small leak coming from somewhere that I cannot see or access, without disconnecting all of the hoses, draining and removing the water heater. However it only leaks when I have the water pump turned on. It appears to be coming from the underside of the water heater. The water heater also has a Watts Thermostatic mixing valve. Anyone have any ideas on the source of the leak, and why it only occurs when the water pump is on?
Thanks, Jeff
Thanks, Jeff
