water heater installation
matt
I have a Universal 2 cylinder diesel, raw water cooled. I would like to use a water heater off this engine when moored in Catalina Is. Any suggestions? Thanks: Matt
Bob Camarena
Not too Difficult
It shouldn't be too difficult. My '81 30' has the water heater installed in the bottom of the port lazerette. The water hose that goes from your engine to the exhaust fitting at the muffler is re-routed to run through the water heater first, then to the exhaust/muffler. The water heater is also hooked up to the shore power circuit so you have hot water at the dock. Don't forget that you still need a vacuum break "U" fitting in the hose circuit.
Dean Bachelor
try seaward products
I have a heater in my 85 C30 it is a seaward brand unit and it works great. Seaward Products 562-699-7997 or www.seawardproducts.com Good luck, Dean
matt
thanks Bob
Thanks Bob, I will try this before my nest trip to Avalon. Rgds: Matt
