Hi,
I have a 1989 Catalina 30 with Universal M25XP motor. I would like to install a water heater and am hoping someone can advise on the installation. I'm wondering if I should use thermostat bypass connection method or take hoses off heat exchanger. What is the preferred method? What are pro and cons with each option. Not sure how the hook up off the HE works...a schematic would be helpful.
Also have heard that air locks can cause problems in the system. How does one bleed off any trapped air?
Thanks in advance.
Thanks in advance.
