Interesting issue, I found the water heater high limit reset switch tripped. Reset it, made hot water via AC power just fine. Fired up engine got to destination, next morning ran the genset to charge and make hot water via AC. Ran it for a while, wife was not pleased with cold shower after my assurances the water should be hot. I have now seen this several times where after the engine runs for a while the high limit switch is tripped. Never trips on just AC I assume because the thermostat on the water heater is shutting it off at a lower temp than the water temp is reaching via the engine coolant loop. Water heater is a Seaward 6 gallon.
Has anyone seen this?
Thanks!
Thanks!
