Ray Stacey
My 6 gallon Atwood water heater in my 1990 Hunter 30 has a problem with it's 110 volt system circuitry. Even with the water heater circuit breaker off, the shore breaker will trip when I make the onboard 110 volt general circuit breaker.I had an electrician quickly diagnose the problem as a "common ground". I disconnected the water heater heating element and the problem went away. I'm getting 10 ohms resistance across the heating element, the same as a new one gives. If anyone can help me diagnose the problem further I would be most grateful.Ray
