W
wfcreadon
I ran into a problem with heating my domestic hot water from the engine loop through it. I have an air lock, as my top hose of my hot water circulation hose is higher than the Radiator Cap. It would be easy to open the hose clamp and push a screwdriver down it and bleed until I get a stream of antifreeze. In the mystical wisdom of prduction building the hot wateer heater cannot be accessed without destroying the aft bunk molding. I can cut an access port but I am looking for another solution. Any ideas???
