Water/fuel in swim lockers on '90 h30
L
Larry Closs
Upon purchasing my H30 in March I noticed some water mixed with oil or fuel sitting in bottom of swim lockers - About 4 or 5 cups in each. I cleaned it out and it has now returned. I do not see any drips or evidence of leaks on fuel tank (mounted in between lockers) or fuel tank hoses. I have no idea where this would be coming from. Is it common? Any ideas on how to figure out cause would be appreciated.
Bob
Diesel or Gas
Larry, do you know what type fuel it is? If diesel I would check where the ladder is bolted to the sugar scoop. Mine was leaking water so I replaced/resealed the ladder mounts and now she is dry. The overflow diesel also has a nasty habit of following the path to the ladder mounts and transom. I take a zip lock baggy and put a few paper towels inside and tape it just below the vent to collect any overflow. It's like candy for manatees. Just kidding I hand the bag to the fuel dock guy and I don't have any mess and none leaks into the water. Other than that I would ask if you keep your dingy motor fuel in that locker. Maybe its leaking. Worst case is (aluninum?)fuel tank leaking. Bob Always Something
