Water filtration question
Jim Ewing
I want to use a water filter when filling up the tank from city water. South Florida is known for its "tasty-tan" water so I was going to use a taste-odor-sediment type whole house filter and rig it up with hose fittings. However, when not in use said filter will be taking full advantage of the warm humid conditions and growing a set of life forms not usually seen. Then the next time I use the filter all this stuff goes into the tank along with the water. Is anybody using a setup like this? If so do you do anything to prevent unwanted biological activity in the filter and housing? I think chlorine would wreck the activated carbon in the filter. I don't know how the filter element would react to some of the biocides used in watermakers. How about air drying the housing and filter between uses? Thanks for any suggestions. Jim "Prospect"
Ron Dagu
Activated charcoal and Chorine
The activated charcoal will not be ruined by the chlorine, it will be removed. Once the charcoal is saturated (I believe the charcoal will absorb about 100 times is own weight), it will cease functioning. I don't see any reason that just drying it out between use, won't stop the "critters" from growing. After dry, I would store in a ziplock bag until used, next time.
